If your laptop display isn't showing up, it's probably because the screen display is broken. This guide shows you how to replace the display screen on your laptop.
Ensure the laptop is powered off.
Flip the laptop over.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$16.96
Use a Phillips #0 screwdriver to remove the six 1 mm screws (circled in red).
Loosen the two captive 1 mm screws on the back corners.
crwdns2935267:0crwdne2935267:0Spudger$3.99
Open up the back cover of the laptop.
Start by unplugging the cable for display.
Remove the 1 mm screws in red circle with Phillips #0 screwdriver.
Remove the 1 mm screws holding down the metal bracket in red circle with Phillips #0 screwdriver.
Unplug both the white and black wire
The black wire is marked in red.
The white wire is marked in orange.
Hold it at a angle and then it should slide off.
