In this guide, we will show you how to remove and replace the Memory Module.
Slide the battery latches to release the battery.
Lift and remove the battery from the computer.
Remove the screw(s) that secures the cover to the computer. Lift the cover upwards.
Slide the cover outwards to release it from the notches on the computer.
Lift the cover upwards and away from the computer.
Pry the retention clips away from the memory module until it pops-up. Lift and remove the memory module from its connector.
