Dell Vostro 3450 Hard Drive Replacement
  1. Dell Vostro 3450 Hard Drive Replacement, Unlocking the Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 Hard Drive Replacement, Removing the Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 Hard Drive Replacement, Press the ExpressCard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the ExpressCard to release it from the computer.
  4. Dell Vostro 3450 Hard Drive Replacement, Slide the ExpressCard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the ExpressCard out of the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  5. Dell Vostro 3450 Hard Drive Replacement, Prying the Keyboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
  6. Dell Vostro 3450 Hard Drive Replacement, Prying the Keyboard retainer: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the second keyboard retainer.
  7. Dell Vostro 3450 Hard Drive Replacement, Pry up the Keyboard Retainer: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the third keyboard retainer.
  8. Dell Vostro 3450 Hard Drive Replacement, Prying the Retainer: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the fourth keyboard retainer.
  9. Dell Vostro 3450 Hard Drive Replacement, Pull up the Keyboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up the keyboard from the palm rest.
  10. Dell Vostro 3450 Hard Drive Replacement, Release the Latch: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the latch on the system board connector, then disconnect the keyboard cable.
  11. Dell Vostro 3450 Hard Drive Replacement, Loosen the Screw: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the screw that secures the memory door.
  12. Dell Vostro 3450 Hard Drive Replacement, Removing the Memory Door: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the memory door near the screw hole, lift and remove it.
  13. Dell Vostro 3450 Hard Drive Replacement, Remove the Screw: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw that secures the optical drive to the computer.
  14. Dell Vostro 3450 Hard Drive Replacement, Prying the Drive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry the optical drive out of the computer.
  15. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that secure the optical drive bracket.
  16. Dell Vostro 3450 Hard Drive Replacement, Removing the Optical Drive: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the optical drive bracket from the optical drive module.
  17. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws in the battery compartment.
  18. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws in the optical drive compartment.
  19. Dell Vostro 3450 Hard Drive Replacement, Remove the Rubber: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber from the bottom base on the right side.
  20. Dell Vostro 3450 Hard Drive Replacement, Remove the Rubber: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber from the bottom base on the left side.
  21. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all the screws from the bottom base.
  22. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the computer around and remove the screws that secures the palm rest.
  23. Dell Vostro 3450 Hard Drive Replacement, Release the Latches: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
  24. Dell Vostro 3450 Hard Drive Replacement, Release the Latch: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the latch on the system board connector and then disconnect the power button cable.
  25. Dell Vostro 3450 Hard Drive Replacement, Disconnecting the Key Cable: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the latch on the system board connector and then disconnect the hot key cable.
  26. Dell Vostro 3450 Hard Drive Replacement, Prying the Palm Rest: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the right side of the palm rest.
  27. Dell Vostro 3450 Hard Drive Replacement, Prying the Palm Rest: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the left side of the palm rest.
  28. Dell Vostro 3450 Hard Drive Replacement, Prying the Sides: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the sides of the palm rest and remove it from the computer.
  29. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that secure the hinge cover.
  30. Dell Vostro 3450 Hard Drive Replacement, Press Down on the Hooks: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press down on the hooks highlighted in the image.
  31. Dell Vostro 3450 Hard Drive Replacement, Removing the Hinge Cover: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the computer around and remove the hinge cover from the side.
  32. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that secure the display hinge.
  33. Dell Vostro 3450 Hard Drive Replacement, Loosen the Screw: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the screw that secures the low-voltage differential signaling (LVDS) cable.
  34. Dell Vostro 3450 Hard Drive Replacement, Disconnecting the LVDS Cable: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the LVDS cable from the system board.
  35. Dell Vostro 3450 Hard Drive Replacement, Disconnecting the Wireless Cables: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the wireless local area network (WLAN) antenna cable.
  36. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that secure the left hinge.
  37. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that secure the right hinge.
  38. Dell Vostro 3450 Hard Drive Replacement, Lifting the Display Assembly: crwdns2935265:038crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the display assembly and remove it from the computer.
  39. Dell Vostro 3450 Hard Drive Replacement, Remove the Screw: crwdns2935265:039crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw that secures the WLAN card.
  40. Dell Vostro 3450 Hard Drive Replacement, Pull the Card: crwdns2935265:040crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the WLAN card straight out of its socket and remove it.
  41. Dell Vostro 3450 Hard Drive Replacement, Release the Latch: crwdns2935265:041crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the latch on the system board and then disconnect the VGA cable.
  42. Dell Vostro 3450 Hard Drive Replacement, Remove the Screw: crwdns2935265:042crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw that secures the VGA board.
  43. Dell Vostro 3450 Hard Drive Replacement, Remove the VGA Board: crwdns2935265:043crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the VGA board from the chassis.
  44. Dell Vostro 3450 Hard Drive Replacement, Disconnect the System Fan Cable: crwdns2935265:044crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the system fan cable from the system board.
  45. Dell Vostro 3450 Hard Drive Replacement, Remove the Screw: crwdns2935265:045crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw that secures the system fan.
  46. Dell Vostro 3450 Hard Drive Replacement, Remove the System Fan: crwdns2935265:046crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the system fan from the bottom base module.
  47. Dell Vostro 3450 Hard Drive Replacement, Disconnect the DC-in Cable: crwdns2935265:047crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the DC-in cable connector from the system board.
  48. Dell Vostro 3450 Hard Drive Replacement, Disconnecting the Speaker Cable: crwdns2935265:048crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the speaker cable from the system board.
  49. Dell Vostro 3450 Hard Drive Replacement, Remove the Screws: crwdns2935265:049crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that secures the system board.
  50. Dell Vostro 3450 Hard Drive Replacement, Disconnecting the System Board: crwdns2935265:050crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the system board from the Input/Output panel.
  51. Dell Vostro 3450 Hard Drive Replacement, Remove the System Board: crwdns2935265:051crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove system board from the chassis.
  52. Dell Vostro 3450 Hard Drive Replacement, Hard Drive: crwdns2935265:052crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that secures the hard drive bracket
  53. Dell Vostro 3450 Hard Drive Replacement: crwdns2935265:053crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the hard-drive module to release it from the system board
  54. Dell Vostro 3450 Hard Drive Replacement: crwdns2935265:054crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hard drive module from the system board.
  55. Dell Vostro 3450 Hard Drive Replacement: crwdns2935265:055crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that secures the hard-drive bracket on one side.
  56. Dell Vostro 3450 Hard Drive Replacement: crwdns2935265:056crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that secures the hard-drive bracket on the other side
  57. Dell Vostro 3450 Hard Drive Replacement: crwdns2935265:057crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the hard drive from the hard-drive bracket.
Johnathan Hammond
crwdns2935283:002/28/18crwdne2935283:0
45,291 crwdns2915208:0crwdne2915208:0
crwdns2935297:0408crwdne2935297:0
RampUP America, Inc. crwdns2935289:0RampUP America, Inc.crwdne2935289:0
Community
crwdns2931471:043crwdne2931471:0
crwdns2935297:01,991crwdne2935297:0
Stupidest HDD location EVER! You have to fully disassemble your device for the simple operation.
vytookas - crwdns2934203:0crwdne2934203:0
Who the !&&* designs a hard drive location that requires complete disassembly of the motherboard and the laptop to replace. Horrible, horrible design.
garbage911garbage - crwdns2934203:0crwdne2934203:0
It’s possible to skip removing the display and the WLAN card, which saves a bit of time and trouble. I think I understand why this guide and Dell’s user guide recommend removing these parts, it makes other steps a _little_ easier, but I didn’t find it was worthwhile.
BorpoIT - crwdns2934203:0crwdne2934203:0
I’ve done this upgrade twice now, and I think the iFixit Opening Tool (along with the spudger) makes this job easier. Besides releasing latches for the palm rest and the memory door, it was very helpful to pry up the System Board from the Input/Output Panel.
crwdns2942667:0crwdne2942667:0 5,201
