Dell Vostro 3450 Display Assembly Replacement
  1. Dell Vostro 3450 Display Assembly Replacement, Unlocking the Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 Display Assembly Replacement, Removing the Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 Display Assembly Replacement, Prying the Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
  4. Dell Vostro 3450 Display Assembly Replacement, Prying the Keyboard retainer: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the second keyboard retainer.
  5. Dell Vostro 3450 Display Assembly Replacement, Pry up the Keyboard Retainer: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the third keyboard retainer.
  6. Dell Vostro 3450 Display Assembly Replacement, Prying the Retainer: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the fourth keyboard retainer.
  7. Dell Vostro 3450 Display Assembly Replacement, Pull up the Keyboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up the keyboard from the palm rest.
  8. Dell Vostro 3450 Display Assembly Replacement, Release the Latch: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the latch on the system board connector, then disconnect the keyboard cable.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  9. Dell Vostro 3450 Display Assembly Replacement, Loosen the Screw: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the screw that secures the memory door.
  10. Dell Vostro 3450 Display Assembly Replacement, Removing the Memory Door: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the memory door near the screw hole, lift and remove it.
  11. Dell Vostro 3450 Display Assembly Replacement, Remove the Screw: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw that secures the optical drive to the computer.
  12. Dell Vostro 3450 Display Assembly Replacement, Prying the Drive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry the optical drive out of the computer.
  13. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that secure the optical drive bracket.
  14. Dell Vostro 3450 Display Assembly Replacement, Removing the Optical Drive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the optical drive bracket from the optical drive module.
  15. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws in the battery compartment.
  16. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws in the optical drive compartment.
  17. Dell Vostro 3450 Display Assembly Replacement, Remove the Rubber: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber from the bottom base on the right side.
  18. Dell Vostro 3450 Display Assembly Replacement, Remove the Rubber: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber from the bottom base on the left side.
  19. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all the screws from the bottom base.
  20. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the computer around and remove the screws that secures the palm rest.
  21. Dell Vostro 3450 Display Assembly Replacement, Release the Latches: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
  22. Dell Vostro 3450 Display Assembly Replacement, Release the Latch: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the latch on the system board connector and then disconnect the power button cable.
  23. Dell Vostro 3450 Display Assembly Replacement, Disconnecting the Key Cable: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the latch on the system board connector and then disconnect the hot key cable.
  24. Dell Vostro 3450 Display Assembly Replacement, Prying the Palm Rest: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the right side of the palm rest.
  25. Dell Vostro 3450 Display Assembly Replacement, Prying the Palm Rest: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the left side of the palm rest.
  26. Dell Vostro 3450 Display Assembly Replacement, Prying the Sides: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the sides of the palm rest and remove it from the computer.
  27. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that secure the display hinge.
  28. Dell Vostro 3450 Display Assembly Replacement, Loosen the Screw: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the screw that secures the low-voltage differential signaling (LVDS) cable.
  29. Dell Vostro 3450 Display Assembly Replacement, Disconnecting the LVDS Cable: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the LVDS cable from the system board.
  30. Dell Vostro 3450 Display Assembly Replacement, Disconnecting the Wireless Cables: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the wireless local area network (WLAN) antenna cable.
  31. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that secure the left hinge.
  32. Dell Vostro 3450 Display Assembly Replacement, Remove the Screws: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that secure the right hinge.
  33. Dell Vostro 3450 Display Assembly Replacement, Lifting the Display Assembly: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the display assembly and remove it from the computer.
Johnathan Hammond
crwdns2935283:002/28/18crwdne2935283:0
45,306 crwdns2915208:0crwdne2915208:0
crwdns2935297:0408crwdne2935297:0
RampUP America, Inc. crwdns2935289:0RampUP America, Inc.crwdne2935289:0
Community
crwdns2931471:043crwdne2931471:0
crwdns2935297:01,991crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 961
