This guide will show you how to replace the disk drive on your Dell Vostro 1500. There will be one screw you need to remove and it should take around five minutes.
Make certain the power is off.
Slide the battery away from the computer.
Unscrew the one 8.5mm Phillips head screw.
Slide out the disk drive. This may require some force.
