Remove the battery from the computer.
Remove all visible screws from the bottom of the computer.
Use a metal spudger to remover the covers of each section that you removed screws from.
Once the cover is removed from the hard drive remove the hard drive by gently tugging it out.
Use the replacement guide for the fan to remove the fan.
You must first unscrew the screws holding the wire in place.
Unhook the wire that the metal spudger is pointing at.
Use the guide to remove the keyboard.
Undo the screws holding the screen to the computer base.
Unplug the wires connecting the screen to the base.
The screen should come free and is able to be removed completely.
Detach the black plastic cover by loosening it with a metal spudger.
Unplug the wire that the metal spudger is pointing to.
