Dell Venue Pro Volume Button Replacement
    1. Dell Venue Pro Volume Button Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the back cover up.
      • Lift the back cover away from the device completely.
    1. Dell Venue Pro Volume Button Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Venue Pro Volume Button Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your finger to lift the battery using the notch in the upper left corner of the compartment.
    1. Dell Venue Pro Volume Button Replacement, Volume Button: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the Back Cover
      • Slide and lift the back cover off the phone. (Use the existing Back Cover Removal guide as reference)
    2. Dell Venue Pro Volume Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the Battery
      • Lift the battery out of its compartment and set it aside.
    3. Dell Venue Pro Volume Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Venue Pro Volume Button Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the Midframe Screws
      • Use a Phillips #00 screwdriver to remove the 4.57 mm screws securing the midframe to the phone.
      • Keep track of each screw and its original location to ensure correct reassembly.
      • Mixing screw lengths can damage internal components during reassembly.
    4. Dell Venue Pro Volume Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Venue Pro Volume Button Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert a plastic opening tool into the seam between the midframe and phone body.
      • Gently twist the tool to release the clips around the edges.
      • Once all clips have disengaged, pull the midframe upward to remove it completely.
      • If the midframe resists, continue sliding the tool along the seam until every clip releases.
    5. Dell Venue Pro Volume Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Expose the Motherboard
      • With the midframe removed, the motherboard should now be fully visible.
      • Identify the following components before continuing:
      • SIM card reader near the top of the device
      • Metal shielding covering the center of the motherboard
      • Micro-USB charging port at the bottom
      • Secondary daughterboard connection on the left side
      • Set the midframe aside.
    6. Dell Venue Pro Volume Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Venue Pro Volume Button Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect Internal Cables
      • At this point, the motherboard should be fully visible, as shown in your reference photos. You should see:
      • Disconnect the following cables:
      • Display cable
      • Any remaining flex cables attached to the motherboard
      • Lift connectors straight up—do not pull on the cables.
    7. Dell Venue Pro Volume Button Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Venue Pro Volume Button Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the Motherboard Screws
      • Use a Phillips #00 screwdriver to remove the 2.68 mm screws securing the motherboard to the frame.
      • Screws are located near:
      • The bottom right corner (charging port area)
      • The middle left side
      • The top of the motherboard
      • Set all screws aside.
      • Using longer screws in motherboard locations can cause permanent damage.
    8. Dell Venue Pro Volume Button Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Venue Pro Volume Button Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Starting from the top edge, gently lift the motherboard up and away from the phone housing.
      • The micro-USB charging port may fit snugly in its opening. Lift carefully to avoid bending the board.
      • Once free, remove the motherboard from the device. Set the motherboard aside.
      • Do not flex or twist the motherboard during removal.
    9. Dell Venue Pro Volume Button Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Venue Pro Volume Button Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the Volume Button Assembly
      • Locate the volume button assembly along the side of the phone frame.
      • Lift the volume button assembly out of its recess.
      • The button contacts are delicate. Remove the assembly carefully.
    10. Dell Venue Pro Volume Button Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Install the New Volume Button Assembly
      • Place the replacement volume button assembly into the phone frame.
      • Ensure it sits flush and aligns correctly with the external button openings.
Todjay A Orr
crwdns2935283:010/29/25crwdne2935283:0
719 crwdns2915208:0crwdne2915208:0
Purdue University Northwest, Team 3-7, Dieterle Fall 2025 crwdns2935289:0Purdue University Northwest, Team 3-7, Dieterle Fall 2025crwdne2935289:0
PNW-DIETERLE-F25S3G7
crwdns2942667:0crwdne2942667:0 139
