Dell Venue 8 Display Replacement
crwdns2869540:0crwdne2869540:0: 7,9 mil
17
94
7.871
crwdns2955950:0crwdne2955950:0: 4
crwdns2960004:02crwdne2960004:0, crwdns2960008:02crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 7
crwdns2959974:07crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 5
crwdns2959982:05crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 10 - 15 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
If your screen is cracked, broken, doesn't respond to touch, or has broken pixels, it might be time to replace the screen. This guide will help you to replace the screen on the Dell Venue 8
    1. Dell Venue 8 Display Replacement, Rear Case/Midframe: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
      • You will hear click sounds as the clips unhinge
      • Remove the back panel of the device.
    2. Dell Venue 8 Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Venue 8 Display Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Venue 8 Display Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
      • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
      • 4.45mm Silver screws
      • 3.6mm Black screws
      • Gently snap the perimeter clips open, and remove the internal plastic case.
    1. Dell Venue 8 Display Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unclip the power clip from the motherboard by pulling down gently towards the bottom of the tablet.
    2. Dell Venue 8 Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently pry the battery away from the device with the plastic opening tool to remove it.
      • The battery is held on to the tablet by a light adhesive
    1. Dell Venue 8 Display Replacement, Speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your plastic opening tool, unclip the speaker connection from the logic board.
      • Caution: Pull directly up, not out, on the connection
    2. Dell Venue 8 Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the speaker by placing using your plastic opening tool in the gap on the top of the speaker and prying it up.
      • The speaker is held on by light adhesive
    1. Dell Venue 8 Display Replacement, Display: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Venue 8 Display Replacement, Display: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect the display clip found next to the speaker.
      • Disconnect the Display connection located at the top of the tablet.
    2. Dell Venue 8 Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unclip the logic board from the Display.
Mitul
crwdns2935283:002/19/15crwdne2935283:0
673 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-2, Leahy Winter 2015 crwdns2935289:0USF Tampa, Team 9-2, Leahy Winter 2015crwdne2935289:0
USFT-LEAHY-W15S9G2
LOL. Who rated this as a difficult repair? Seriously? T5 screws too much for you? The only issue with the repair for this device is the adhesive between the digi and frame is a REAL pain to remove, and the plastic frame is likely to melt if you use too much/high heat. Otherwise, it's very simple. Just be careful when installing the new digi, as the motherboard needs to be slightly lifted to feed the connector.
Rene - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thanks for the instructions!
Is there a part 2 for this guide? The instructions is incomplete and doesn't not include steps to actually remove the digitizer.
Franklin Ramos - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 94
crwdns2959996:0crwdne2959996:0 7,871
