Is your screen cracked or damaged? Replacing your screen might help solve these issues.
Face the device with the screen towards you.
With a plastic opening tool, pry open the bottom left corner of the screen.
Next, pry open the top left corner of the screen.
Then, pry open the top right corner of the screen.
Lastly, pry open the bottom right corner of the screen.
Once you have pried open all the corners of the tablet, carefully open the screen from the right side of the tablet.
Once the tablet is opened, locate the connector.
Disconnect the connector from the tablet.
i wanted to replace the battery but dont know how to pry the screen open, is it attached with glue? thanks in advance.
Where can I find a replacement screen for this device?
Is the OLED connected with EDP 30=pin FPC?
