Dell Venue 8 7840 Power and Volume Button Replacement
  1. Dell Venue 8 7840 Power and Volume Button Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure your device is turned off. Leaving it turned on may cause an electric shock.
    • Face the device with the screen towards you.
  2. Dell Venue 8 7840 Power and Volume Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a plastic opening tool, pry open the bottom left corner of the screen.
    • The screen is tightly attached to the tablet, so you may have to use a metal spudger to pry it open if the plastic spudger does not do the task.
  3. Dell Venue 8 7840 Power and Volume Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next, pry open the top left corner of the screen.
  4. Dell Venue 8 7840 Power and Volume Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Then, pry open the top right corner of the screen.
  5. Dell Venue 8 7840 Power and Volume Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lastly, pry open the bottom right corner of the screen.
  6. Dell Venue 8 7840 Power and Volume Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have pried open all the corners of the tablet, carefully open the screen from the right side of the tablet.
    • Do not try and open the screen from the left side of the tablet, because the screen is attached on the left side of the tablet; doing this can damage the tablet.
  7. Dell Venue 8 7840 Power and Volume Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the tablet is opened, locate the connector.
  8. Dell Venue 8 7840 Power and Volume Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the connector from the tablet.
  9. Dell Venue 8 7840 Power and Volume Button Replacement, Battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the eight 7 mm Philips #1 screws.
    • After the screws are unscrewed, you can take off the silver cover.
  10. Dell Venue 8 7840 Power and Volume Button Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using tweezers, disconnect the battery from the tablet.
    • After disconnecting the battery, you can remove the battery from the tablet.
  11. Dell Venue 8 7840 Power and Volume Button Replacement, Power and Volume Button: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Venue 8 7840 Power and Volume Button Replacement, Power and Volume Button: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, pry open the left side of the tablet.
    • Locate the power and volume buttons.
  12. Dell Venue 8 7840 Power and Volume Button Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, push out the volume button from the left side of the tablet.
  13. Dell Venue 8 7840 Power and Volume Button Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure that you hold the left side of the tablet open with a plastic opening tool so that you will be able to take out the volume button.
    • With tweezers, pull out the volume button.
  14. Dell Venue 8 7840 Power and Volume Button Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a plastic opening tool, push out the power button from the left side of the tablet.
  15. Dell Venue 8 7840 Power and Volume Button Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Just like the volume button, you want to make sure that you hold the left side of the tablet open with a plastic opening tool so that you will be able to take out the power button.
    • With tweezers, pull out the power button.
Donnelle January
crwdns2935283:009/12/16crwdne2935283:0
429 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 6-5, Remmell Fall 2016 crwdns2935289:0USF Tampa, Team 6-5, Remmell Fall 2016crwdne2935289:0
USFT-REMMELL-F16S6G5
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 843
