If you want to replace the speaker you must first get a new one. Once you do, then you are ready to follow these easy steps.
Use a spudger or your fingers to pry off the back case.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
Remove the battery by pulling it from the edges and carefully peeling it off of the base.
Use a spudger to remove the ribbon cable that is around the speaker wire.
Disconnect the speaker wire from the motherboard by prying the connector upwards with the spudger.
Remove the plastic covering on the speaker.
Gently pull on the wire and remove the speaker.
