Dell Venue 7 Motherboard Replacement
  1. Dell Venue 7 Motherboard Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Venue 7 Motherboard Replacement, Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Motherboard Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
  4. Dell Venue 7 Motherboard Replacement, Rear Facing Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to disconnect the camera from the motherboard.
  5. Dell Venue 7 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the camera from the device.
  6. Dell Venue 7 Motherboard Replacement, Speaker: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Venue 7 Motherboard Replacement, Speaker: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to remove the ribbon cable that is around the speaker wire.
  7. Dell Venue 7 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Venue 7 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the speaker wire from the motherboard by prying the connector upwards with the spudger.
  8. Dell Venue 7 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic covering on the speaker.
  9. Dell Venue 7 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Venue 7 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull on the wire and remove the speaker.
    When I was pulling the speaker out the wire had broken where can I get the speaker?
    ginovirgiltthiruchudar - crwdns2934203:0crwdne2934203:0
  10. Dell Venue 7 Motherboard Replacement, Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Venue 7 Motherboard Replacement, Motherboard: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Venue 7 Motherboard Replacement, Motherboard: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the two remaining connections on the motherboard.
    • To remove the first connector, lift up the clasp and remove the ribbon cable.
    • To remove the second one, use a spudger to gently pry the connector from the motherboard.
  11. Dell Venue 7 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Venue 7 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all 8 of the 2.1mm Phillips head screws from the motherboard.
  12. Dell Venue 7 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the motherboard from the device.
crwdns2935229:08crwdne2935229:0
Stephen Rousseau
crwdns2935283:001/20/15crwdne2935283:0
663 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 11-4, Blackwell Winter 2015 crwdns2935289:0USF Tampa, Team 11-4, Blackwell Winter 2015crwdne2935289:0
USFT-BLACKWELL-W15S11G4
unable to open the lock, can the mother board be changed
Amitabh Mishra - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,530
