Many components are connected to the motherboard so confirm that all of the components work before you decide to replace the whole motherboard.
Use a spudger or your fingers to pry off the back case.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
Remove the battery by pulling it from the edges and carefully peeling it off of the base.
Use a spudger to disconnect the camera from the motherboard.
Use a spudger to remove the ribbon cable that is around the speaker wire.
Disconnect the speaker wire from the motherboard by prying the connector upwards with the spudger.
Remove the plastic covering on the speaker.
Gently pull on the wire and remove the speaker.
Disconnect the two remaining connections on the motherboard.
To remove the first connector, lift up the clasp and remove the ribbon cable.
To remove the second one, use a spudger to gently pry the connector from the motherboard.
Remove all 8 of the 2.1mm Phillips head screws from the motherboard.
Lift and remove the motherboard from the device.
crwdns2935229:08crwdne2935229:0
unable to open the lock, can the mother board be changed
Great article.
