If your battery will not hold a charge you may need to replace it. The battery is located on the underside of the laptop. No tools are required for this guide.
Turn off and unplug the laptop.
Flip the laptop so the underside is facing up with the battery closest to you.
Slide the locking switch to the left to release the battery.
Gently pull the battery away from the device.
