Dell Streak 7 Headphone Jack Replacement
  1. Dell Streak 7 Headphone Jack Replacement, Front Panel Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
  2. Dell Streak 7 Headphone Jack Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the button cover by lifting the cover away from the tablet.
  3. Dell Streak 7 Headphone Jack Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Torx screwdriver, remove the 4mm screws.
  4. Dell Streak 7 Headphone Jack Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the Torx screwdriver, remove the two 5mm screws.
  5. Dell Streak 7 Headphone Jack Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Streak 7 Headphone Jack Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
  6. Dell Streak 7 Headphone Jack Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
  7. Dell Streak 7 Headphone Jack Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Streak 7 Headphone Jack Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
  8. Dell Streak 7 Headphone Jack Replacement, Headphone Jack: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the spudger, disconnect the ribbon cable by lifting up on the connector.
    • Ribbon cables are fragile and easily broken.
  9. Dell Streak 7 Headphone Jack Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Streak 7 Headphone Jack Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the headphone jack up, away from the case.
Ali Benjelloun
crwdns2935283:010/02/16crwdne2935283:0
376 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 4-6, Passmore Fall 2016 crwdns2935289:0USF Tampa, Team 4-6, Passmore Fall 2016crwdne2935289:0
USFT-PASSMORE-F16S4G6
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 222
