Use this guide to replace the headphone jack on your Dell Streak 7. This guide will show you how to remove the old headphone jack.
Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
Remove the button cover by lifting the cover away from the tablet.
Using the Torx screwdriver, remove the 4mm screws.
With the Torx screwdriver, remove the two 5mm screws.
Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
With the Torx screwdriver, remove the two 4mm screws.
Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
Using the spudger, disconnect the ribbon cable by lifting up on the connector.
Pull the headphone jack up, away from the case.
