Dell Streak 10 Pro Speakers Replacement
  1. Dell Streak 10 Pro Speakers Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the device flat on its screen.
    • Using the plastic opening tools, pry open the top segment of the tablet where the camera is located.
    • Take the segment off and place it to the side.
  2. Dell Streak 10 Pro Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four 4mm Phillips #0 screws.
  3. Dell Streak 10 Pro Speakers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, lift off the entire back screen of the tablet.
  4. Dell Streak 10 Pro Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the no-fuss ribbon cable connector.
    • The best way is to safely pull the white connector straight out of the socket. Using the tweezers, pull out the white connector that contains the red, green, blue, and black cords connected to it.
    • Remove the battery by gently lifting it out of the device.
  5. Dell Streak 10 Pro Speakers Replacement, SD Card Breakout Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement, SD Card Breakout Board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove three 4mm Phillips #0 screws.
  6. Dell Streak 10 Pro Speakers Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift up the black covered wire and place it on the side, so that it is not in the way of the procedure.
  7. Dell Streak 10 Pro Speakers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When encountering a zero insertion force connector, the best way it to carefully use tweezers to flip up the white locking flap securing the blue-tipped ribbon cable.
    • Then, gently use the tweezers to pull out the blue-tipped ribbon cable from the unlatched connector.
  8. Dell Streak 10 Pro Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use two fingers and gently pull the SD card breakout board from its space.
  9. Dell Streak 10 Pro Speakers Replacement, Speakers: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement, Speakers: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement, Speakers: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are five ribbon cables in a row that must be disconnected.
    • Using the tweezers, carefully pull out the first cable straight out of the no-fuss ribbon cable connector.
  10. Dell Streak 10 Pro Speakers Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the tweezers, carefully pull out the cable straight out of the no-fuss ribbon cable connector.
  11. Dell Streak 10 Pro Speakers Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When dealing with a zero insertion force connector, the best way it to carefully use a tweezer to flip up the white locking flap holding the blue-tipped ribbon cable.
    • Then, gently remove the ribbon cable from the socket.
  12. Dell Streak 10 Pro Speakers Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When dealing with a zero insertion force connector, the best way it to carefully use a tweezer to flip up the white locking flap holding the blue tip wire.
    • Then gently remove the wire from the socket.
  13. Dell Streak 10 Pro Speakers Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the adhesive tapes using the tweezers.
  14. Dell Streak 10 Pro Speakers Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the tweezers, carefully flip up the locking tab on the Zero Insertion Force connector.
    • Then, gently disconnect the orange ribbon cable.
  15. Dell Streak 10 Pro Speakers Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing all the adhesive strips, gently lift up the sensor board as to not bend it.
  16. Dell Streak 10 Pro Speakers Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When dealing with a zero insertion force connector, the best way it to carefully use a tweezer to flip up the white locking flap holding the orange ribbon cable.
    • Once the white tab is lifted, use the tweezer to carefully pull out the orange ribbon cable.
  17. Dell Streak 10 Pro Speakers Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your fingers, wiggle the speaker until it comes free from the device. Carefully remove it from the tablet.
  18. Dell Streak 10 Pro Speakers Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Streak 10 Pro Speakers Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your fingers, wiggle the other speaker until it comes free. Carefully remove it from the tablet.
  19. Dell Streak 10 Pro Speakers Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull out the connected speakers.
Matthew Ko
crwdns2935283:002/05/19crwdne2935283:0
440 crwdns2915208:0crwdne2915208:0
UC Davis, Team S20-G7, Lore Winter 2019 crwdns2935289:0UC Davis, Team S20-G7, Lore Winter 2019crwdne2935289:0
UCD-LORE-W19S20G7
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 138
