Dell Precision T3400 Video Card Replacement
    1. Dell Precision T3400 Video Card Replacement, Remove the computer's side panel.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Precision T3400 Video Card Replacement, Remove the computer's side panel.: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lay the computer on its side so the panel faces up.
      • Push the cover release latch at the back of the computer's case. The cover should pop off and away from the computer.
      • Make sure the computer is on its side before you begin replacing any parts.
    1. Dell Precision T3400 Video Card Replacement, Move the heat-sink assembly lever out of the way: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Push the tab on the blue plastic secure lever and pivot the lever down and away from the assembly
      • Make sure you ground yourself to prevent static discharge
    2. Dell Precision T3400 Video Card Replacement, Open the video card secure hatch.: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Precision T3400 Video Card Replacement, Open the video card secure hatch.: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Squeeze the two release tabs together and pivot the secure hatch to the right to open.
    3. Dell Precision T3400 Video Card Replacement, Remove the video card: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Hold the card by its top corner and metal bracket and pull it out of its slot.
    4. Dell Precision T3400 Video Card Replacement, Install the new video card: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Precision T3400 Video Card Replacement, Install the new video card: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Match the new card’s connectors with the notches in the slot and gently push it into place. The card should click into position when inserted correctly.
      • Close the card door and move the blue plastic secure lever back into place.\
      • Ensure that the card you are replacing the existing card with meets wattage and connectivity requirements. Do not force a card into the slot.
To reassemble your device, follow these instructions in reverse order. Step 1: Install new card and latch it in place. Step 2: Reinstall the side panel. Step 3: Plug everything back in
crwdns2935229:08crwdne2935229:0
Josette Cormier
crwdns2935283:009/10/13crwdne2935283:0
13 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 crwdns2935289:0UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013crwdne2935289:0
UMASSD-GULBRANDSEN-F13S1G2
crwdns2935297:084crwdne2935297:0
Does it have PCI-E 2.0?
What dimensions the graphics card can have?
Maxime Raguenet - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 7,519
