Dell Precision T3400 Power Supply Replacement
  1. Dell Precision T3400 Power Supply Replacement, Disconnect the DC power cables from the system board and the drives.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pay special attention to where the DC power cables are plugged in so that they can be replaced the same way.
    • You may need to remove the heat-sink assembly in order to detach certain cables.
  2. Dell Precision T3400 Power Supply Replacement, Remove the power supply from the computer case.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws on the back of the power supply using a standard Phillips-head screwdriver.
  3. Dell Precision T3400 Power Supply Replacement, Remove the power supply from the computer case.: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the secure tab down and slide the power supply out of its bracket to remove it.
  4. Dell Precision T3400 Power Supply Replacement, Install the new power supply.: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the power supply into the empty bracket. It will click into place.
    • Replace the four screws to secure the power supply to the computer case.
  5. Dell Precision T3400 Power Supply Replacement, Reconnect the DC power cables.: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remember to use the case's secure tabs to hold cables out of the way.
    • If you removed the heat-sink assembly in order to remove any power supply cables, be sure to re-install the assembly.
crwdns2935229:09crwdne2935229:0
Josette Cormier
crwdns2935283:009/10/13crwdne2935283:0
13 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 crwdns2935289:0UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013crwdne2935289:0
UMASSD-GULBRANDSEN-F13S1G2
crwdns2942667:0crwdne2942667:0 8,615
