Dell Precision M6600 LCD Replacement
  1. Dell Precision M6600 LCD Replacement, LCD: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the laptop lid fully and place it on a stable surface to access the screen.
    • Make sure the laptop is unplugged and the battery is removed to prevent electrical hazards.
  2. Dell Precision M6600 LCD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Precision M6600 LCD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the iFixit opening tool to carefully pry around the edges of the screen bezel, starting from a corner or along the bottom edge. Gently work around the perimeter to release each of the clips.
    • Once it has been loosened, lift the bezel away from the display and set it aside in a safe place to prevent any damage.
  3. Dell Precision M6600 LCD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the screws securing the LCD screen to the display frame.
    • Once all screws are removed, set them aside in a safe place.
  4. Dell Precision M6600 LCD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully disconnect the gold LCD cable from the back of the screen by gently pulling on only the connector, not the cable itself.
    • LCD connectors are fragile. apply gentle, even pressure when disconnecting to avoid bending or breaking the pins.
    • Once the cable is fully detached, lift the LCD screen out of the display assembly and place it on a clean, flat surface to prevent scratches or damage.
Kaley lindsay
crwdns2935283:003/23/18crwdne2935283:0
582 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S8-G3, Valliere Spring 2018 crwdns2935289:0UMass Dartmouth, Team S8-G3, Valliere Spring 2018crwdne2935289:0
UMASSD-VALLIERE-S18S8G3
crwdns2942667:0crwdne2942667:0 1,110
