Dell Precision M6600 Hard Drive Replacement
  1. Dell Precision M6600 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the lock key to unlock the battery. Then you can lift the battery from its holder.
  2. Dell Precision M6600 Hard Drive Replacement, Remove Bottom Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Precision M6600 Hard Drive Replacement, Remove Bottom Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using Phillips screwdriver, remove 2 screws holding case.
    • Slide case towards back of laptop then lift off to remove.
  3. Dell Precision M6600 Hard Drive Replacement, Remove the Hard Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Precision M6600 Hard Drive Replacement, Remove the Hard Drive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips Screwdriver, remove the 4 screws that hold the hard drive in place.
    • Using a Phillips #00 take out the 1.5mm screw then slide to unlock the SSD holder.
    There is also four more screws holding the drive in place, two at the front of the drive and two at the sides, These will need to be taken out before the drive holder will slide out.
    Willaim Chalmers - crwdns2934203:0crwdne2934203:0
  4. Dell Precision M6600 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When the lock was slid, a medal holder popped out and that is where the SSD is hidden.
Kaley lindsay
crwdns2935283:003/23/18crwdne2935283:0
582 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S8-G3, Valliere Spring 2018 crwdns2935289:0UMass Dartmouth, Team S8-G3, Valliere Spring 2018crwdne2935289:0
UMASSD-VALLIERE-S18S8G3
How do you remove the bottom? Instructions only show removal of battery then next step shows full access to bottom of laptop? My slide switch doesn’t release the door, any thoughts?
Jason Zuehlke - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 87
crwdns2942667:0crwdne2942667:0 4,197
