Dell Precision M4800 Wi-Fi Card Replacement
  1. Dell Precision M4800 Wi-Fi Card Replacement, Wi-Fi Card: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Wi-Fi Card Replacement, Wi-Fi Card: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Wi-Fi Card Replacement, Wi-Fi Card: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Ensure that all electrical sources are removed and turned off.
    • Unplug the charger from the laptop and shut it down.
    • Flip the computer, so the bottom is facing upwards.
    • Slide the release latch to release the battery.
    • Lift and remove the battery from the laptop.
    The series of photos and action shots (showing your hands) gives a clear overview of the initial steps of the repair. Well done! Check iFixit's conventions for markup (your arrow), and notice that the direction it is pointing in is in the opposite direction to the one that your finger seems to be pointing toward. This could be confusing to readers because your finger is more prominent than the red arrow (which is hard to see against the black background of your laptop) so readers are likely to get the impression that the catch should slide in the direction that the finger is pointing in. Could you re-shoot the photo so that the visual information is consistent?
    Ros Woodhouse - crwdns2934203:0crwdne2934203:0
  2. Dell Precision M4800 Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the two 5 mm screws fastening the backplate.
    • Slide the base cover towards the rear of the laptop.
    • Lift the base cover and remove it from the laptop.
  3. Dell Precision M4800 Wi-Fi Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Wi-Fi Card Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Wi-Fi Card Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the black and white antenna cables by carefully pulling them upwards away from the card, being cautious to not bend the connector.
    • For the antenna pins a simple and slight nudge is usually enough, but remember that these pins are somewhat delicate.
    • Remove the screw.
    I'm not sure what is different between the first two shots, apart from the red rectangle. Use one, or re-shoot so the difference is easier to see.
  4. Dell Precision M4800 Wi-Fi Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Precision M4800 Wi-Fi Card Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Wi-Fi card.
  5. Dell Precision M4800 Wi-Fi Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Precision M4800 Wi-Fi Card Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the replacement Wi-Fi card into the slot.
    • Tighten the screw securing the Wi-Fi card.
    This looks like reassembly. See iFixit's instructions for this.
  6. Dell Precision M4800 Wi-Fi Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Precision M4800 Wi-Fi Card Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Connect both antenna cables back to the same places according to the color code on the Wi-Fi card.
  7. Dell Precision M4800 Wi-Fi Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Wi-Fi Card Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Wi-Fi Card Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the base cover towards the front of the laptop.
    • Slide the battery back into its place.
    • Make sure to put a little pressure on it if the battery is not fully in place. The battery release latch will automatically click back to the locked position.
Naveen
crwdns2935283:009/19/23crwdne2935283:0
195 crwdns2915208:0crwdne2915208:0
York University, Team B-19, Woodhouse Fall 2023 crwdns2935289:0York University, Team B-19, Woodhouse Fall 2023crwdne2935289:0
YORK-WOODHOUSE-F23SBG19
Great guide, well-written and concise. Thank you for sharing your knowledge and expertise. Best regards
Loren Martin - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 1,020
