Dell Precision M4800 Four Slot RAM Replacement
  1. Dell Precision M4800 Four Slot RAM Replacement, DDR3 Ram Card: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Four Slot RAM Replacement, DDR3 Ram Card: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Four Slot RAM Replacement, DDR3 Ram Card: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Ensure that all electrical sources are removed and turned off.
    • Unplug the charger from the computer.
    • Flip the computer, so the bottom is facing upwards.
    • Slide the release latch to release the battery.
    • Lift and remove the battery from the computer.
  2. Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the two 5 mm screws fastening the backplate.
    • Slide the base cover towards the rear of the computer.
    • Lift the base cover and remove it from the computer,
  3. Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the retention clips away from the RAM card simultaneously.
    • Lift the RAM card upwards.
    • Pull the first RAM card away from the slot.
    • Repeat this step to remove the second RAM card.
  4. Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the replacement RAM card back into the slot diagonally.
    • The RAM card is keyed and will only go into the slot in one orientation.
    • Lightly press the RAM card into the computer.
    • Ensure the RAM card is seated properly. Both tabs should be secured to the RAM card's grooves.
  5. Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a guitar pick or an iFixit Opening Pick, pry a section of the keyboard trim.
    • Gently lift the trim with your finger until multiple tabs of the keyboard trim are unclipped. Go around the trim and unclip all tabs one by one.
    • While lifting the trim you will hear multiple snaps. This is normal as multiple tabs may unclip at once.
    • Once all the tabs are unclipped, remove the keyboard trim from the device.
  6. Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove the three 3 mm screws.
    • Ensure that all the screws are completely removed from the keyboard. They will easily get lost in the computer if they fall out.
    • Lift the keyboard gently from retaining clips.
    • Do not immediately remove the keyboard from the computer. You could damage a connector if you lift it up too quickly or rip it away.
    the keyboard is held on the side by several clips. if one gently flexes/curves the keyboard upward a bit in the middle (by the front retaining prongs) this will pull the keyboard sides away and they will gently 'pop' out from under the side clips.
    penny murphy - crwdns2934203:0crwdne2934203:0
  7. Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the ribbon connector that attaches the keyboard to the motherboard.
    • Remove the keyboard.
  8. Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the retention clips away from the first RAM card simultaneously.
    • Lift the first RAM card upwards.
  9. Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the retention clips away from the second RAM card simultaneously.
    • Lift the second RAM card upwards.
    • Pull the second RAM card away from the slot.
  10. Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the first replacement RAM card into the slot at an angle.
  11. Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Precision M4800 Four Slot RAM Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the second replacement RAM card into the slot at an angle.
    • The RAM card is keyed and will only go into the slot at one orientation.
Mason Byrd
crwdns2935283:002/02/21crwdne2935283:0
208 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S7-G2, Rauch Spring 2021 crwdns2935289:0Embry-Riddle Aeronautical University, Team S7-G2, Rauch Spring 2021crwdne2935289:0
ERAU-RAUCH-S21S7G2
Posting in case this helps anyone else. I was donated 2 Dell Precision M4800 laptops with i7 processors. Both had newest BIOS I could find, A26 Dec 2019.
I put 4x4 GB RAM for a total of 16 GB in the laptop with i7 4710M and all was recognized.
When I put 4x4 GB RAM for a total of 16 GB in the laptop with i7 4610M, only slots AB (bottom of laptop) were recognized, for a total of 8 GB. If I removed the RAM sticks from slots AB, then slots CD (under keyboard) were recognized for a total of 8 GB. I could not get all 4 slots (ABCD) to be recognized.
I think the problem is the CPU i7 4610 is dual core, and only recognizes a maximum of 2 slots of RAM. The CPU i7 4710M is quad core and can recognize all 4 slots of RAM.
I tested with 2x 8GB sticks in i7 4610M and it recognized 16 GB RAM.
Jessica - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 55
crwdns2942667:0crwdne2942667:0 4,457
