The first step in any kind of replacement is to remove the back cover on the laptop.
Before beginning, be sure to power down the laptop and unplug it from any external power source(s). This guide will show you how to remove the back cover in your laptop.
Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
Lift up the silver cover from the back panel to reveal two screws.
Use a Phillips screwdriver to remove the two screws underneath the silver cover.
Use an opening tool to pry around the edges of the back panel to loosen the panel.
Remove the back panel.
