Dell Precision 7560 Keyboard Replacement
  1. Dell Precision 7560 Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Precision 7560 Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Precision 7560 Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Precision 7560 Keyboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Precision 7560 Keyboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
    It is only 3 screws to remove the battery. Each one is labeled M2x5L on the tabs extending from the battery.
    Barry Todd - crwdns2934203:0crwdne2934203:0
  3. Dell Precision 7560 Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Precision 7560 Keyboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Precision 7560 Keyboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Keyboard Replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Precision 7560 Keyboard Replacement, Keyboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Precision 7560 Keyboard Replacement, Keyboard: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the back cover and battery removed, locate the ribbon cables connected to the keyboard.
    • Pulling from the tab, carefully remove the connector.
  5. Dell Precision 7560 Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Precision 7560 Keyboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Precision 7560 Keyboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the device over and open the screen to expose the keyboard.
    • Using an opener tool, pry along the edges of the keyboard to remove the keyboard's plate cover.
  6. Dell Precision 7560 Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Precision 7560 Keyboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Precision 7560 Keyboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the plate cover removed, use the screwdriver to remove each of the six 2 mm screws.
    • Carefully remove the keyboard from the device.
    There is a 7th keyboard screw above and left of the “7/Home” key.
    MikeP - crwdns2934203:0crwdne2934203:0
    There is one more screw between the [Backspace], [Num Lock], [\], [home] keys.
Jack Allred
crwdns2935283:002/09/23crwdne2935283:0
345 crwdns2915208:0crwdne2915208:0
Utah Tech University, Team 1-1, McMurrin Spring 2023 crwdns2935289:0Utah Tech University, Team 1-1, McMurrin Spring 2023crwdne2935289:0
UTAHTECH-MCMURRIN-S23S1G1
Guide is close, but not completely correct. Just need a little more attention to detail.
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 1,175
