This guide covers how to replace the battery in a Dell Precison 7560. When replacing the battery, make sure to completely power off your device. Not doing so will cause a Fire Hazard. The battery is responsible for powering your device, so it is very hazardous.
Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
Remove the back cover by lifting at the corners.
Unscrew and remove the five 2 mm screws that secure the battery.
Locate the battery connector.
Pull the connector towards you to disconnect it.
Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
Was able to reset a battery that stopped charging with these instructions, appreciate it!
