This guide will teach you how to disassemble your Dell Precision 3510 computer to remove the battery. Before you follow this guide, check out the troubleshooting pages and confirm that the operating battery will need to be removed.
Before you begin the steps to remove the Dell Precision 3510 Computer battery, power the computer off completely and unplug any external devices. You can power off your computer by holding down the power button in the upper right-hand corner of the keyboard for 10-15 seconds.
Flip the computer over so that you are looking at the bottom.
Use a Phillips #000 screwdriver to remove the eight 6.5 mm screws from the base cover.
Use the opening tool to carefully pry the base cover from the computer.
Remove the base cover from the laptop.
Using a Phillips #000 screwdriver, remove the two 5.5 mm screws from the battery.
Gently unplug the cable connected to the top of the battery.
Remove the battery from the laptop.
