Well, this probably doesn't even need a guide on how to do but oh well. Here it is! The Dell PowerEdge T410 Drive Replacement!
So, to begin, take your Server and take a look. What do you see? Depending on the Model, it'll all be similar, yet have differences between the two. Both models have a removeable Faceplate and Side Panel. The Faceplate will be removeable on the front at the top parallel to the front IO and system Info Monitor.
Just like a regular desktop, the Chassis Side Panel is able to be removed to access the main Cavity and the rest of the internal Components. Simple as that.
For the Hotswappable Model, remove the Faceplate. But for the Internal Sled Model, there is no way to access from removing the Faceplate because it is only accessible through the Internal Component Bay.
The first model, the Hotswap HDD Sleds, simply opens with a latch at the top of the Front Panel. Once that is unlatched, pull it out and down and you have immediate access to the drives.
With the Internal HDD Sled Model, you can just disengage the latch for that panel and pull the side off of it. Make sure to pull forward on the side panel because going the wrong direction, you simply are unable to open it.
Once you pull the sleds out, the system will lose connection to the Drives. So backup your data to a different drive inside the system if upgrading, or simply pull it out and use a replacement from the store or Cold Storage.
To remove the HDD Sleds, there is a handle that pulls out by a Tensioned Switch, and once out you can Undo the Screws holding the Drive in place, and even replace it with an SSD (if you have a 2.5" Drive sled, that is) and get even more speed from the newly installed drive.
For the Internal HDD Sleds, you can simply pull out when the computer is inactive because the system is not intended to be ran when removing internal drives just like a regular desktop.
To close up your Server, either fit your front panel on the guides at the bottom of the Chassis' Front, and/or do the same with the Side Panel.
