Dell Optiplex GX620 CMOS Battery Replacement
  1. Dell Optiplex GX620 CMOS Battery Replacement, How to unplug and discharge before repair: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Optiplex GX620 CMOS Battery Replacement, How to unplug and discharge before repair: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 CMOS Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Optiplex GX620 CMOS Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 CMOS Battery Replacement, Dell Optiplex GX620 Side Panel Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 CMOS Battery Replacement, Removing the CMOS Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a tool beside the battery and gently pry the battery out.
    • Using a screwdriver to pry open anything can harm your device. Instead, use a spudger or a plastic opening tool.
To reassemble your device, follow these instructions in reverse order. Make sure you place the battery with the flat (positive) side facing up.
crwdns2935229:09crwdne2935229:0
Kristina
crwdns2935283:009/03/14crwdne2935283:0
210 crwdns2915208:0crwdne2915208:0
Pasco Hernando, Team 5-1, Prince Fall 2014 crwdns2935289:0Pasco Hernando, Team 5-1, Prince Fall 2014crwdne2935289:0
PHSC-PRINCE-F14S5G1
crwdns2931471:010crwdne2931471:0
Thank you for this. It gave me the courage to do the job, and told me how. I'm very, very grateful.
Richard Samuel - crwdns2934203:0crwdne2934203:0
Shouldn't the battery be listed in the parts? Squinting at the photo, it seems to be a CR2032?
vcayenne - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 58
crwdns2942667:0crwdne2942667:0 16,258
