Dell Optiplex 745 Ultra Small Form Factor CPU Replacement
  1. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, Side Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure to shut down the computer! Go to the start menu and click shutdown from the power options first
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the computer on its side; you will see a blue knob.
    • Turn said knob 90 degrees counter clockwise.
  3. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While the knob is still turned, slide the panel case forward about 1/2 inch, and then lift the panel off the computer.
  4. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU Heat Sink: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU Heat Sink: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the blue shield by sliding it straight upwards.
  5. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull back on the tab nearest to the front case fan.
    • Slide the CPU heat sink from under the clip and pull upward.
    • You may need to twist the CPU heat sink side to side to free it from the thermal paste.
  6. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Ground yourself before removing any internal components.
    • Push release lever down slightly and away from CPU.
  7. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and rotate processor cover off of CPU.
    • Processor cover will remain attached.
  8. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using two fingers holding the sides, lift the CPU from the socket.
    • Do not touch the underside of the CPU or any of the pins.
    • When replacing the CPU, do not use excessive force.
    • Ensure to use the alignment-notches on the new CPU, when replacing.
donnavon
crwdns2935283:009/02/14crwdne2935283:0
707 crwdns2915208:0crwdne2915208:0
Pasco Hernando, Team 1-1, Prince Fall 2014 crwdns2935289:0Pasco Hernando, Team 1-1, Prince Fall 2014crwdne2935289:0
PHSC-PRINCE-F14S1G1
crwdns2931471:011crwdne2931471:0
crwdns2917034:0crwdne2917034:0
crwdns2942667:0crwdne2942667:0 2,160
