Dell OptiPlex GX260 Power Supply Replacement
  1. Dell OptiPlex GX260 Power Supply Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell OptiPlex GX260 Power Supply Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Power Supply Replacement, Power Supply: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the power supply in the case.
    • Disconnect the AXT power cable to the motherboard.
    • Disconnect the P4 12 volt power cable from the motherboard.
    • Disconnect the power cable from the optical drive.
    • Disconnect the floppy drive power cable.
    • Disconnect the hard drive power cable.
  3. Dell OptiPlex GX260 Power Supply Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Phillip screws holding the power supply into the the case and lift the power supply out.
    • When installing a new power supply ensure that the voltage selector is correctly set before you connect the mains cable.
    • Incorrect voltage settings will damage the power supply and may also cause other components to be damaged.
  4. Dell OptiPlex GX260 Power Supply Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push down on the green tab with one hand.
    • With your other hand, grip the top of the power supply and pull back and up to remove from the case.
Kevin Schapansky
crwdns2935283:010/05/10crwdne2935283:0
1.478 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-48, Amido Fall 2010 crwdns2935289:0Cal Poly, Team 4-48, Amido Fall 2010crwdne2935289:0
CPSU-AMIDO-F10S4G48
crwdns2935297:027crwdne2935297:0
In mine, the power supply was much longer due to a fan located on the front end. Same basic disassembly, however. There was a green tab at the front and it was difficult, but the power supply (with effort) did slide forward and out.
jknox - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 13,600
