Dell OptiPlex GX260 Hard Drive Replacement
  1. Dell OptiPlex GX260 Hard Drive Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell OptiPlex GX260 Hard Drive Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
    cool de faires des sites comme ca :)
    baptiste Prando - crwdns2934203:0crwdne2934203:0
    mm pas mon fere
    Thoma Delanou -
    Excellent - Only comment - do the the green brackets come with a new hard drive or should I leave them inside the case for the next owner - Removing to donate to recycling
    sheila_jones - crwdns2934203:0crwdne2934203:0
    I got this yesterday....up and running now....how on earth do I MERGE the 18GB partition D with C....there is just NO option there.
    Elvis 1357 - crwdns2934203:0crwdne2934203:0
    Also, want to add another HD....but, there are no cables at all?
  2. Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Identify the Hard Drive in the case.
    • If there is more than one hard drive installed the process is the same for each hard drive.
    • Remove the power cable from the hard drive by squeezing the side tabs in and pulling gently.
    • Remove the IDE cable from the hard drive by gently pulling the ribbon cable out.
  3. Dell OptiPlex GX260 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pinch the two green tabs inwards to release the hard drive and lift it out.
    buenos dias como se llama las pieza de color verde que trai el disco duro que trai en los lados
    Pedro Eduardo Garza Alanis - crwdns2934203:0crwdne2934203:0
crwdns2935229:09crwdne2935229:0
Kevin Schapansky
crwdns2935283:010/05/10crwdne2935283:0
1 478 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-48, Amido Fall 2010 crwdns2935289:0Cal Poly, Team 4-48, Amido Fall 2010crwdne2935289:0
CPSU-AMIDO-F10S4G48
crwdns2935297:027crwdne2935297:0
crwdns2942667:0crwdne2942667:0 19,065
