Make sure the Dell Latitude X300 power is off.
Remove the battery located on the bottom of the device by pushing in both clips.
Remove the 4 mm screws located on the front screen of the laptop.
Carefully, remove the screen casing using either your hands or a proper tool.
Remove the 4 mm screws on the bottom left and bottom right corner of the screen.
Carefully lift the screen and place it on it's face.
Disconnect the wiring attached to the screen.
