Turn the laptop over so that the bottom is facing up.
Remove the two #0 3 mm screws holding the cover plate.
Push both metal retaining clips outward at the same time using your hands carefully.
Gently pull the memory out of the retainer at the same 45 degree angle.
Insert the new memory at 45 degree angle.
Ensure the memory is in all the way before pressing the memory downward until both metal retainer clips are snapped into place.
To reassemble your device, reinstall cover plate with two #0 screws.
