Dell Latitude X300 Palm Rest/Track Pad Replacement
  1. Dell Latitude X300 Palm Rest/Track Pad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before removing the battery from the laptop, make sure the power is off.
    • Push both battery locking clips outward at the same time.
  2. Dell Latitude X300 Palm Rest/Track Pad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery out of the laptop.
  3. Dell Latitude X300 Palm Rest/Track Pad Replacement, Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4 mm Phillips #0 screws from the bottom of the laptop.
  4. Dell Latitude X300 Palm Rest/Track Pad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude X300 Palm Rest/Track Pad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully turn the laptop over and open the screen all the way.
    • Locate the slot to remove the keyboard in the lower left hand corner.
    • Using a spudger as a lever, insert it into the slot and gently pry up.
  5. Dell Latitude X300 Palm Rest/Track Pad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
    • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
  6. Dell Latitude X300 Palm Rest/Track Pad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
  7. Dell Latitude X300 Palm Rest/Track Pad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the flexible ribbon from the ZIF connector.
    • Do not pull on the ribbon to remove it from the ZIF connector.
  8. Dell Latitude X300 Palm Rest/Track Pad Replacement, Palm Rest/Track Pad: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Position the laptop so that the bottom is facing upward.
    • Remove the three 4 mm Phillips #0 screws holding the bottom of the palm rest.
  9. Dell Latitude X300 Palm Rest/Track Pad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Return the laptop to proper position and open the screen.
    • Remove the six 4 mm Phillips #0 screws holding in the palm rest.
  10. Dell Latitude X300 Palm Rest/Track Pad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the palm rest and rotate it outward so that the bottom is now facing up.
    • The ribbon attached to the track is short and extremely delicate. Use care when moving the palm rest.
  11. Dell Latitude X300 Palm Rest/Track Pad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up on the small ZIF connector and remove the ribbon.
    • If the ribbon seems stuck, gently wiggle it to remove. Do not pull the ribbon with great force.
Thomas Wong
crwdns2935283:001/20/12crwdne2935283:0
23 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-20, Maness Winter 2012 crwdns2935289:0Cal Poly, Team 11-20, Maness Winter 2012crwdne2935289:0
CPSU-MANESS-W12S11G20
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 973
