This is a step-by-step guide on how to replace the Latch on the Dell Latitude X300 laptop. You will need a Philips screwdriver and a replacement latch to complete this repair. This repair will be needed if the latch used to open the laptop is broken, such as:
- Preventing the device from closing fully
- Not effectively keeping the device closed
- The latch gets stuck often.
- Laptop is locked shut.
Remove the battery located on the bottom of the device by pushing in both clips.
Remove rubber caps on each corner of the front screen with a pinch.
Remove the 4 mm screws located on the front screen of the laptop.
Carefully, remove the screen casing using either your hands or a proper tool.
Remove the screws holding the latch in place.
Replace the old latch with the new one
