Before removing/replacing the Dell Latitude X300 hard drive, the battery, keyboard, and palm rest/trackpad will need to be removed.
Push both battery locking clips outward at the same time.
Remove the four 4 mm Phillips #0 screws from the bottom of the laptop.
Carefully turn the laptop over and open the screen all the way.
Locate the slot to remove the keyboard in the lower left hand corner.
Using a spudger as a lever, insert it into the slot and gently pry up.
After the keyboard pops up, pull it away from the screen just enough to release the tabs.
Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
Remove the flexible ribbon from the ZIF connector.
Position the laptop so that the bottom is facing upward.
Remove the three 4 mm Phillips #0 screws holding the bottom of the palm rest.
Return the laptop to proper position and open the screen.
Remove the six 4 mm Phillips #0 screws holding in the palm rest.
Gently lift the palm rest and rotate it outward so that the bottom is now facing up.
Lift up on the small ZIF connector and remove the ribbon.
Remove the 4 #00 5 mm screws holding the hard drive to the case.
Carefully pull up on the hard molded plastic portion of the ribbon to detach it from the computer.
Remove the hard drive from the laptop.
I have to know cause its long time ago i was using this pc,
and i really forgot my HD password and dont know where to find it,sorry
