Dell Latitude ST Motherboard Replacement
  1. Dell Latitude ST Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the back panel tab.
    • Press down on the tab to remove the panel.
  2. Dell Latitude ST Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the four 6mm screws attaching the inside panel to the device.
  3. Dell Latitude ST Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the blue plastic opening tool to push in the tab located on the backside of the device.
    • Slide the tool around the edges of the device to unsnap the tabs and pry the frame off.
  4. Dell Latitude ST Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 6mm Phillips #0 screws attaching the battery.
  5. Dell Latitude ST Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your hands or a plastic opening tool, unplug the white battery cable.
    • Push forward on the top part of the cable to disconnect it from the device.
  6. Dell Latitude ST Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the black tab located at the top of the battery to remove the battery from the device.
  7. Dell Latitude ST Motherboard Replacement, Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude ST Motherboard Replacement, Motherboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3mm Phillips #0 screw from the SSD drive which is located above the speaker and to the left of the motherboard.
  8. Dell Latitude ST Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the white and black cables attached to the WLAN to unplug them.
    • Remove the one 3mm the Phillips #0 screw attached to the WLAN card.
    • Remove the WLAN card.
  9. Dell Latitude ST Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the copper tape to loosen it from the screen.
    • Unscrew the seven 6mm the Phillips #0 screws from the base.
  10. Dell Latitude ST Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the grey LCD cable attached to the motherboad on the device.
    • Pull up the black tape handle attached to the LCD cable to disconnect it.
  11. Dell Latitude ST Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your hands or the blue plastic opening tool, go along the edges of the frame and unsnap the screen from the middle frame.
  12. Dell Latitude ST Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn over the middle frame.
    • Pull on the white cables with the blue tape to disconnect them.
  13. Dell Latitude ST Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the middle frame back over.
    • Unplug the three white cables attached to the motherboard.
    • Use the blue plastic opening tool to push down on the cables to disconnect them.
  14. Dell Latitude ST Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the last motherboard cable attached to the bottom of the frame and the motherboard.
    • With the blue plastic opening tool, flip up the white latch on the top part of the cable.
    • Pull up on the cable using the blue plastic opening tool to disconnect it from the motherboard.
  15. Dell Latitude ST Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude ST Motherboard Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the single 6mm screw attaching the motherboard.
    • Remove the Motherboard from the middle frame of the device.
Addie Kenney
crwdns2935283:004/11/17crwdne2935283:0
416 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S1-G1, Crane Spring 2017 crwdns2935289:0Eastern Washington University, Team S1-G1, Crane Spring 2017crwdne2935289:0
EWU-CRANE-S17S1G1
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 702
