If the laptop tends to overheat, this could be a result of the fan not functioning properly. The following is a step-by-step guide to remove and replace the fan in the Dell Latitude E6510.
Push the two tabs in and pull out the battery pack.
Remove the 5 screws from the back panel of the laptop using a Type 0 Phillips Head screwdriver.
Slide the back panel off of the computer.
Carefully detach the fan power supply cable.
Remove the two screws connecting the fan to the laptop using a type 0 head Phillips screwdriver.
