crwdns2937539:0crwdnd2937539:0crwdne2937539:0
The Dell Latitude E7470 laptop's internal speaker units are responsible for audio output and are paired for stereo sound. If one or both units fail, sound output is compromised. Signs of a failing speaker include decreased volume, distortion, or garbled sound. The left and right speakers are hardwired together and sold as a single unit.
Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
If you are removing an extended capacity battery, remove the Phillips screw securing the bottom right corner of the battery.
Unplug the four pin speaker connector from the motherboard.
De-route the speaker wire harness from the guide rails.
Use a Phillips #0 screwdriver to remove the left and right mouse button assembly screws.
Starting with the left speaker (your right), carefully lift the units away and de-route the wire harness linking them.
