Dell Latitude E7470 SSD Replacement
  1. Dell Latitude E7470 SSD Replacement, Open cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude E7470 SSD Replacement, Open cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude E7470 SSD Replacement, Open cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin by removing the 8 screws circled in red on the photo opposite with a Philips # 0 screwdriver.
    • Next, using the iFixit Opening Picks, lift the cover up from the dock connector. Unclip it gently.
    It's a good idea to disconnect the Battery before removing any components. This is the pull tab to the left of the NAND SSD and above the battery
    Richard Holmes - crwdns2934203:0crwdne2934203:0
  2. Dell Latitude E7470 SSD Replacement, Changing the SSD: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude E7470 SSD Replacement, Changing the SSD: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude E7470 SSD Replacement, Changing the SSD: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the cover, the SSD slot is on the bottom right, right next to the battery.
    • Make sure you have grounded yourself before you start handling. There is a huge risk of damaging components. Use an antistatic wrist strap.
    • To remove the SSD, simply remove the single screw that holds it. Lift the SSD to a 30-degree angle and pull it from its slot.
To reassemble your device, follow the instructions in reverse order.
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Hyperion
crwdns2935283:012/13/15crwdne2935283:0
2 051 crwdns2915208:0crwdne2915208:0
crwdns2947412:08crwdne2947412:0
Does the M.2 interface in this board support NVMe M.2 SSD’s?
Kinetik - crwdns2934203:0crwdne2934203:0
It does! It has only one plastic piece (I forgot what the proper term is), not 2.
Luke Johnson -
It’s not working for me with Kingston nvme NV1
Ravi Bhargava - crwdns2934203:0crwdne2934203:0
If no ram or ssd do ya got to put windows 10 back on I got no recover usb .or a dell recovery usb with 10 or what was original on it .its a e7470
Mike Heiss - crwdns2934203:0crwdne2934203:0
Without RAM you cannot start the computer, it is an essential component.
Without SSD you have no storage so you can't install Windows.
Hyperion -
Is it possible to install two SSD on this Dell Latitude e7470 laptop? I am currently eyeing one and would like to know if to purchase an extra SSD for it.
Thanks in advance.
Ekerette Ekpo - crwdns2934203:0crwdne2934203:0
No extra slot for a extra ssd card. But you can insert High capacity SD card into the Card Slot to give you more disk memory.!
Burgert Adriaan Potgieter -
Dumb question maybe - how do you get the cover back on? The front specifically doesn't seem to line up with anything on the main chassis.
Michael Jantzen - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 99
crwdns2942667:0crwdne2942667:0 21,383
