Dell Latitude E7470 Motherboard Replacement
  1. Dell Latitude E7470 Motherboard Replacement, RAM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude E7470 Motherboard Replacement, RAM: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the two clips beside the RAM stick and pull them outward. The RAM stick should release.
    • Remove the RAM from the device.
    • Repeat this for second RAM stick
  2. Dell Latitude E7470 Motherboard Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
    Personally, I would remove the battery as the first stage battery should be disconnected before any work is completed.
    Richard Holmes - crwdns2934203:0crwdne2934203:0
  3. Dell Latitude E7470 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude E7470 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
    • If you are removing an extended capacity battery, remove the Phillips screw securing the bottom right corner of the battery.
    My laptop had 2 screws holding the battery. I am not sure why. It may be useful to check whether yours has 2 as well. Unlike the laptop’s back cover, after unscrewing the screws on the battery, you have to remove the screws.
    Victor Ashiedu - crwdns2934203:0crwdne2934203:0
    I too have 2 battery screws. My battery is longer than the one pictured. I think my battery must be an extended capacity battery.
    What I do not understand is that in the picture, on the extreme right - next to the computer's outside edge, there is a round CMOS battery pictured with a red/black twisted pair of wires plugging into the motherboard. My machine has an empty space with no battery. What about the machines of others? Was there one that has been removed? My machine seems to work ok without it. Should I install one?
    wilie - crwdns2934203:0crwdne2934203:0
  4. Dell Latitude E7470 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the laptop.
  5. Dell Latitude E7470 Motherboard Replacement, Fan and Heatsink: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude E7470 Motherboard Replacement, Fan and Heatsink: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After opening the backcase of the computer, remove the screws using the Phillips #0 screwdriver.
    • Unplug and remove the wire from the socket.
  6. Dell Latitude E7470 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fan and heatsink from the laptop.
    • Make sure to wipe off the existing thermal paste from the CPU and heatsink with an alcohol-soaked pad and apply a new layer.
    Why do you have to remove the heatsink when it can just be lifted out with the motherboard?
    Jarrod Findon - crwdns2934203:0crwdne2934203:0
  7. Dell Latitude E7470 Motherboard Replacement, Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude E7470 Motherboard Replacement, Motherboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude E7470 Motherboard Replacement, Motherboard: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all the screws using a Phillips #0 screwdriver.
    • Disconnect all of the cables from the motherboard.
    In order to access the two screws near the docking port, you need to remove the docking port cover. This is released by removing the two screws on the rear edge of the case and then lifting the part clear - assuming you have removed all the other screws.
    The screws on the board are hidden by the two-round caps, on either side of the docking port.
  8. Dell Latitude E7470 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard from the laptop.
Bo Zeng
crwdns2935283:010/01/19crwdne2935283:0
406 crwdns2915208:0crwdne2915208:0
Duke University Pratt School of Engineering, Team S4-G3, Matos-Garner Fall 2019 crwdns2935289:0Duke University Pratt School of Engineering, Team S4-G3, Matos-Garner Fall 2019crwdne2935289:0
DUKEPSE-MATOS-GARNER-F19S4G3
crwdns2935297:011crwdne2935297:0
Good overall, the motherboard screw picture shows too many screws. Also, might need a picture of removing the two side screws for the port cover, and that there are two screws next to the expansion port, under the port cover.
Charles Coburn - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,035
