crwdns2937539:0crwdnd2937539:0crwdne2937539:0
Dell Latitude E7470 Display Replacement
  1. Dell Latitude E7470  Display Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
  2. Dell Latitude E7470  Display Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
  3. Dell Latitude E7470  Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude E7470  Display Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
    • If you are removing an extended capacity battery, remove the Phillips screw securing the bottom right corner of the battery.
  4. Dell Latitude E7470  Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the laptop.
  5. Dell Latitude E7470  Display Replacement, Display: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove screws which are indicated by red circles . Gently unplug the write connector, marked by the red square, out of the grey socket.
  6. Dell Latitude E7470  Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove wires in protectors (red circles) and remove the screw in red square. Pick the wires out of the motherboard.
  7. Dell Latitude E7470  Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude E7470  Display Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude E7470  Display Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two side screws on the surface of computer's connector parts.
    • Remove the five 0.4 cm screws in the red circle
  8. Dell Latitude E7470  Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude E7470  Display Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use spudger to pry the display bezel.
  9. Dell Latitude E7470  Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This the screen part can be replaced. Make sure you buy the correct size!
Yihao Huang
crwdns2935283:010/01/19crwdne2935283:0
172 crwdns2915208:0crwdne2915208:0
Duke University Pratt School of Engineering, Team S4-G3, Matos-Garner Fall 2019 crwdns2935289:0Duke University Pratt School of Engineering, Team S4-G3, Matos-Garner Fall 2019crwdne2935289:0
DUKEPSE-MATOS-GARNER-F19S4G3
crwdns2935297:011crwdne2935297:0
You do not need to take the entire computer apart. The bezel can come off while still hinged to the main body giving you access to the four screws holding on the display. Unless you need to replace the main display ribbon cable, the screen itself is straightforward to replace.
Shane Pritchard - crwdns2934203:0crwdne2934203:0
If you are replacing the bezel at the same time - don't forget to check that the clear film has been removed from the webcam lens. A foggy image is not reassuring when testing the reassembled computer.
Richard Holmes - crwdns2934203:0crwdne2934203:0
Hi. Where is the inverter located in an e7470?
Is it integrated along the bottom of the lcd unit? Can it be bought separately and replaced? Thx if you can help.
Howard - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 70
crwdns2942667:0crwdne2942667:0 3,346
