Dell Latitude E7450 CMOS battery Replacement
    • Before performing this task, make sure you turn off the computer and disconnect everything from it.
    • Remove the battery from the computer by sliding the release latch.
    • Remove the computer cover by unscrewing the two screws highlighted in the picture.
    • Disconnect the CMOS battery from its connector and remove from the system board.
    • Replace the battery by plugging the connector to the board and placing the battery in the correct position.
    • If you want to reset the BIOS, press and hold the power button for 10-20 seconds to drain residual power.
If you are trying to reset the BIOS Admin Password, I would recommend this tutorial :)
https://www.youtube.com/watch?v=9LugtKgf...
Brandon
crwdns2935283:004/23/22crwdne2935283:0
85 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 315
