You may have noticed your computer slowing down when using several programs. This is likely a result of insufficient RAM. Fortunately, Dell made RAM replacement straightforward, allowing you to easily upgrade your RAM capacity.
Power off your laptop before starting.
Flip the device over so that the vents on the bottom are facing away from you.
Place your finger on the latch located in the center of the laptop.
Slide the latch to the right, applying enough force to reveal a red indicator.
Lift the battery by the top, away from the laptop body.
Remove two M2 x 3mm Phillips #0 screws from the base cover.
Slide the base cover down slightly and remove it.
For each RAM module, pull apart both the clips and remove the memory.
