Dell Latitude E7270 Solid State Drive Replacement
  1. Dell Latitude E7270 Solid State Drive Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Solid State Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
    are you sure they are M2.5x8mm? they look more like M2x8mm
    Charles Beauchemin - crwdns2934203:0crwdne2934203:0
    The screws should be captive, so no need to remove them completely.
    engiNURD - crwdns2934203:0crwdne2934203:0
  3. Dell Latitude E7270 Solid State Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the panel.
  4. Dell Latitude E7270 Solid State Drive Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
    FYI - You only remove the 2 outer screws as the hole in the middle is used by a screw on the base cover.
    CJ NI - crwdns2934203:0crwdne2934203:0
    If you have a 3-cell, 42Whr battery (Type 7CJRC; DPN: 021X15), you only remove one screw, near the plug of the battery.
  5. Dell Latitude E7270 Solid State Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude E7270 Solid State Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 Solid State Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
  7. Dell Latitude E7270 Solid State Drive Replacement, Solid State Drive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the SSD stick on the bottom right of the device.
    • In the absence of an SSD, a RAM stick was used as a substitute for visual and educational purposes only. The SSD in your device will resemble a RAM stick but may differ in color.
  8. Dell Latitude E7270 Solid State Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the SSD of its socket.
Jacob Clement
crwdns2935283:001/14/20crwdne2935283:0
876 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S16-G5, Branham Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S16-G5, Branham Spring 2020crwdne2935289:0
ERAU-BRANHAM-S20S16G5
Thumbs down for showing a memory module and not a SSD.
Christopher Gehringer - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 4,592
