How to Disassemble a Laptop Fan to Replace Thermal Paste
First remove the 3 screws to remove the lead
Then remove those 7 screws in order and try to keep track of which each screw place for when you assemble it back
carefully shake the heatsink until the thermal past loosens and it moves freely
Now pull down the heat sink from its place
Clean off the old thermal paste from the heat sink, CPU, and GPU, and then apply the new thermal paste
put everything back into place, and don't forget to attack the connector to its place, and with that you are done
