Looking to upgrade your memory? Use this guide to upgrade or replace the RAM on your Dell Latitude E6510.
Use a J1 screwdriver to remove the 8mm screw on the bottom cover.
There should be four steps to this, step two should be removing the 4 hard drive screws,
step three should be removing the bottom cover, including that it slides off, as many bottom covers snap in.
I almost damaged the bottom cover trying to pry it up.
