Dell Latitude E6430 thermal paste Replacement
  1. Dell Latitude E6430 thermal paste Replacement, Opening up: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude E6430 thermal paste Replacement, Opening up: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude E6430 thermal paste Replacement, Opening up: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Start by removing the battery using the 2 latches (red rectangles)
    • All screws to be removed are marked with a D (green circles)
    • The hard disk or ssd has a shared screw with the d-cover (backcover). Also remove the screw below. (blue circle)
  2. Dell Latitude E6430 thermal paste Replacement, DVD drive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude E6430 thermal paste Replacement, DVD drive: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the dvd drive just press on the button marked with a red rectangle.
    • It will then pop out and may be used to just pull out the drive. Easy as cake.
  3. Dell Latitude E6430 thermal paste Replacement, Lift the lid: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude E6430 thermal paste Replacement, Lift the lid: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude E6430 thermal paste Replacement, Lift the lid: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To finally open the device turn it by 180 degrees and pry open from the backside with a spudger.
    • You will see that the d-cover is mounted to the other side.
    • Remove the cover and turn the device back like seen in image no 3.
  4. Dell Latitude E6430 thermal paste Replacement, Removing the heatsink: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude E6430 thermal paste Replacement, Removing the heatsink: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude E6430 thermal paste Replacement, Removing the heatsink: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are four screws with springs on them which have to be removed in the order embossed on the heatsink. (red circles)
    • Also make sure to unplug the fan very carefully. (pink rectangle)
    • Remove the heatsink by lifting it out to the left side as it is fixed on the right side.
    • The cpu DIE lies bare in front of you - this is a very sensitive part. This is why the heatsink is screwed on in a particular order.
  5. Dell Latitude E6430 thermal paste Replacement, Cleaning: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude E6430 thermal paste Replacement, Cleaning: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude E6430 thermal paste Replacement, Cleaning: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Both the cpu DIE and the copper part of the heatsink should be cleaned as the thermal paste tends to dry out over time.
    • Use a cotton swab with some rubbing alcohol.
    • Never use a screwdriver or anything hard that might damage or scratch the surface.
  6. Dell Latitude E6430 thermal paste Replacement, Reapply thermal paste: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use thermal paste of your liking and apply a thin layer (I almost used too much).
    • The thermal pad (red circle) should not be replaced with thermal paste. If it seems dried out you have to use one of the same size.
    • Reattach the heatsink very carefully and tighten the screws in the given order. Also don't forget to connect the fan.
    • If your fan seems to be clogged with dust you should clean it while it's removed.
crwdns2935229:05crwdne2935229:0
Fred
3,522 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 1,629
