Dell Latitude E6420 Fan Replacement
  1. Dell Latitude E6420 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude E6420 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Fan Replacement, CD/DVD Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude E6420 Fan Replacement, CD/DVD Drive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the button in on the CD/DVD drive to eject the drive.
  4. Dell Latitude E6420 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude E6420 Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the drive out of the laptop.
    • When removing the drive, keep it flat to prevent damage to anything inside the laptop.
  5. Dell Latitude E6420 Fan Replacement, Backplate: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude E6420 Fan Replacement, Backplate: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
    • Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
  6. Dell Latitude E6420 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude E6420 Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
    • Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
  7. Dell Latitude E6420 Fan Replacement, Fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude E6420 Fan Replacement, Fan: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the screwdriver, remove four 10mm Phillips #0 spring screws from the fan assembly.
  8. Dell Latitude E6420 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude E6420 Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to unclip the connector.
  9. Dell Latitude E6420 Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the fan out of the laptop.
Madysen Eames
crwdns2935283:002/27/18crwdne2935283:0
1,555 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S2-G3, Simcock Spring 2018 crwdns2935289:0UMass Dartmouth, Team S2-G3, Simcock Spring 2018crwdne2935289:0
UMASSD-SIMCOCK-S18S2G3
very good explanatory steps. but you did not talk about the application of thermal paste for reassembly
Godwin Nwachukwu - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,463
